Today was more clean up, including a couple of hours spent on the shop. I drilled the inside left door post out to #30 and then deburred. I also worked to final drill, clean prep and prime the upper door curve and get it ready for final riveting. Finally, I began work on the right door post and the final drilling of the upper curve and stiffeners on the outside of the door post.
