Jerrys Web Site
Date:  12-4-2014
Number of Hours:  6.00
Brief Description:  Flight Controls
Today was a clean up day. I changed out the bolts in the slider assembly for the correct ones. I also changed the bolts out in the rudder pedal brake assembly for the correct ones. I drilled the inside right post for the access cover, then installed nutplates. Unfortunately, I used the incorrect rivets and will redo that after the correct ones arrive. Finally, I measured carefully for the flap control torque tube and drilled two pilot holes on the sides of the fuselage. I intend to cut the hole in the ceiling for the flap horn prior to installation. I also widened a couple of the holes where the aileron control cables pass through the horizontal post members, as they were border line rubbing the edges.
