Today, I finished the oiverhead mixing unit box. I finished the final match drilling, and then deburred, cleaned and primed the cover plate. I made the four corner clips and installed them as well. When complete, I bolted the mixing unit side plates in place, and unfortunately, the slider assembly didn't slide. Ugh -- the clearances are so tight I'll need to do some thinking and perhaps some sanding to remove a bit of material on the slider block.
