Jerrys Web Site
Date: 9-9-2014
Number of Hours: 8.00
Brief Description: Forward Floor
Today, I spent an incredible amount of time working on the floor panel. Cleaned and primed, and drilled all the necessary holes. I also made clips to hold the master cylinders in place per the change bulletin.
However, a lot of the time I spent trying to decide exactly what to do. The plans are very lacking in this area. After some correspondence with Murphy, I realized my RP-17 bars for the interconnect braking system were the older straight ones. Murphy strongly recommends you use the newer curved ones. However, they are $28 each. That's basically the price of another master cylinder. So, Since I'm almost there, I believe I'll just go ahead and order another set of servos and have dual cylinders for braking, one on each side. And, now is the time to do it before everything is bolted in place.
There are no instructions on how to best mount the servos, so I did the best I could from other pictures and references.
Everything in Place
