Jerrys Web Site
Date:  8-1-2014
Number of Hours:  6.00
Brief Description:  Tail Cone and Firewall
Today, we finished cutting out the access hole doublers for the lower tail cone area. After cleaning and priming, we riveted them in the inside of the tail cone. I drilled 3/16 inch holes for rivenuts and will dimple my access covers with my rivenut dimpler, similar to what I did for all the others. While Julien was final riveting, I worked on the firewall, marking the two upper outboard engine mount holes, then removed the firewall and drilled them to size. Next, I installed a large 3" channel horizontally across the upper firewall, with the ends centered on the engine mount holes. I'll post a picture during the next work period.
Access Doublers Installed
Vertical Fin and Lower Cone Riveted
Marking upper Engine Mount Holes
