Jerrys Web Site
Date:  3-3-2014
Number of Hours:  4.00
Brief Description:  Cabin Sills
Today, I worked to match drill the sills. I used cargo straps to tighten the sills in place and then a 12 inch drill to reach the tabs from the inside. You drill from the top down. I raised the two side walls up higher to hold stations 5-8 in their correct vertical position. In addition, I found I needed to remove the sill and temporarily cleco the float attach fittings in place before drilling stations 7-8. Otherwise, they may twist a bit and the float fittings may not fit afterwards. I still have four more carrythrough end caps to drill. the two at Station 8 will be very difficult, as those are the two where the flanges face the same direction, and there is little clearance to reach the tabs on station 8.
Match Drilling the Sills
Sill drilled
Sill drilled
Ready to drill
Ready to drill
