Jerrys Web Site
Date: 6-15-2012
Number of Hours: 2.50
Brief Description: Wing Rotisserie and Saw Horses
This afternoon, I worked on moving the wing assembly off the table on the rotisserie. I scooted each side one foot at a time. In the end, I missed the CG, as it is front heavy. It should equal out when I get the skin on. Then, I made some sturdy sawhorses that I saw on You Tube. I made them 1/2 inch less than the rotisserie, and it is easy to lift up and remove the rotisserie. This way, I can slide the rotisserie back in, move the saw horses out, and flip the wing by myself. It will help during construction and during painting. I'll need to change my attach on the outboard end for painting, but will figure it out.
Wing on Rotisserie
Outboard attach
On sawhorses, rotisserie removed
