Today, I completed work on the left aileron. I cleaned up the rivet heads, and then installed the access covers with rivnuts. I then turned the wing over, and installed the aileron per the plans with a five degree up reflex. I then began to trim the wing tip, first cutting off the packing flange. I also compelted installation of the framework around the aileron spade.
