Today, I removed the plastic from all the left wing parts except the skins. I then cleaned up the shims -- they had quite a few tool marks. I cleaned them on the belt sander and rounded the edges slightly. Then, I matched drilled from a master made from the spar. I used the drill press and Tap Magic Fluid for AL to drill. Finally, I drew the lines on the nose ribs.
