Jerrys Web Site
Date: 1-11-2012
Number of Hours: 7.50
Brief Description: Wing and Tank Skin Installation
Today, I had a neighbor come over and help turn the wing back over so the bottom skin was up. That's when I realized, I got ahead of myself last night -- I had cleco'd the leading edge skin on the top. Because of the wing strut fitting, I had to remove the cleco's and begin again from the bottom. Then, I riveted the tank skin, dipping each rivet in proseal. I then went ahead and riveted the bottom wing skin in place, except for the main spar and the trailing edge. I'll wait until I can level it up properly with the top wing skin in place.
This evening, I had my neigbor Chris and his son Christopher come over to help turn the wing back over. Christopher is in the first picture. I spent the rest of the evening cleco'ing the leading edge skin in place. I used a long 2x4 on the leading edge and some 2" web straps with blocking behind the rear spar to draw it up tight. I cleco'd everything except the last several holes, so I can slide the wing/tank skin in place.
Next, I'll proseal around the rivet tails in the tank, then begin to rivet the leading edge in place.
Neighbor Christopher helping to turn wing over
Inside view of outboard fuel bay
Wing ready for top skin
