Brief Description: Wing and Tank Skin Installation
Today, I deburred everything I could reach with the bottom wing/tank skin off. Then, I cut out and fitted the four stringer brackets (actually eight as they are two part) to the top of the wing. They go on the outboard side of the rib, so you can install them after the tank skin is installed. Finally, I fitted the two tank access frames and covers. All the little things take time. Next session, I will work on more doublers and inspection holes in the bottom wing skin.
