Brief Description: Wing and Tank Skin Installation
Today, I finished match drilling and cleco'ing the upper skin, including the leading edge. I then had a neighbor help turn the wing over. I spent the rest of the evening trying to pull the leading edge tight enough to cleco it. Tomorrow, I will try adding blocks of wood to the trailing edge and use a strap (ratcheting) to dray it up a bit tighter. It is a really tight fit.
