Jerrys Web Site
Date: 10-28-2011
Number of Hours: 3.00
Brief Description: Rib Assembly
Today, I realized I had installed the incorrect avex rivet for the rib assembly to the main spar. The SR manual didn't call out the specific rivet, so I used RV-1631. In researching the Moose manual, it called for RV-1621 (1/2 max grip length), except for the spar caps, then 1631s. So this morning, I drilled the heads off, pushed them through with a small punch, and re-riveted. I had no problem with holes enlargening etc. Then, I completed assembly of three more rib sets I had primed yesterday. When complete, I began work on the root rib, specifically the nose rib and the area for the delrin bearing (flight controls). I installed four anchor nuts for the Delrin Bearing in the nose rib, then sanded the hole smooth with a drum sander until the bearing just fit nice and tight.
Ribs assembled up to fuel tank area
close up of Avex rivets on ribs
Anchor nuts in root rib for delrin bearing
