Today, I mounted the ELT on the frame I fabricated earlier. I routed the antenna cable from the antenna directly above, down behind bulhead D, attached it with Adel clamps, and to the ELT. I drilled a new wire path forward for the "telephone" type cable, as well as the transponder antenna cable. I installed the transponder antenna and ran a coax cable to attach at a later date. I need to get a coax cutter first.
