Again, more work on the Vans Air Box snout, clamping the fuel pump overflow hose, and the breather tube assembly. In addition, I added a few more Adel clamps to finish off a couple of things. I added cotter pins to the exhaust ball joints, and pro sealed the two adel clamps in place that hold the exhaust clamps on the lower engine mount stubs. It all takes longer than you expect. In addition, I did a bit of work on the lower cowling. I also received my large flange rivets in the mail, and was able to finish riveting the windshield flange.
