Today, I spent some time on my back, installing the DSUB connector into the back of the VM1000C EMS. This was the connector with the EGT/CHT probes etc. I also worked to secure the cables up front of the firewall. I installed the connectors in the engine fuel pump and on the VANS manifold on the firewall. I plan to run my fuel primer lines from there. I also ran some clear poly tubing on the AN4 fittings to meaure the hose distances. I need to get some larger tubing to complete the job of measuring, and make a final determination on the flow scan cube.
