Today, I finished installing the angled ribs and then removed the skin and deburred everything. In addition, I primed the interior of the elevator skin, and then worked on final assembly of the elevator frame, including the elevator control horn. I also made the elevator control horn doublers per the modification from Murphy Aircraft/and then primed them. The next step will be to check everything and then continue attaching the skin to the elevator framework per the plans.
