Today, I split the Delrin spacers on the bandsaw, and then removed each wing with my wing stand, and added the spacers to the forward spar attach point. Next, I installed two correct bolts in the rudder linkage, and then added rivnuts to the right flap. The flap access panels had not been drilled out or rivnuts installed.
Since it was a beautiful day, 60 degrees, no wind and clear, I rearranged the hangar and moved the Cygnet up front. I went for two separate rides this afternoon. Great landings.
