Today, I did some more work on my paint booth. The plastic kept falling off the wall so I screwed it in place with 1x2s on the wall side. I also found a lot of cardboard to place around my six 4x8 sheets of 1/4 inch OSB. Next, I finished removing a bit more of plastic, and then moved the fuselage out of the garage. I cleaned the upper surfaces with soap and water. Then, we moved the fuselage from the garage back into the shop for painting.
