Today, I removed the seats and doors from the fuselage. I spent some time going over the fuselage and completing a bit of riveting, basically in areas where I ran out of the correct rivet size. I then filled a couple of holes that had been misdrilled. Next, I spent several hours with my dremel cleaning up rough mandrel edges on rivets. After lunch, I began taping windows with 3M vinyl tape, then the 3M paint tape. I also removed the cowling, and took a bit of time to install another heat muff. Tomorrow, finish taping, adding paper, and scuffing and cleaning the aluminum.
