Jerrys Web Site
Date:  9-1-2014
Number of Hours:  6.00
Brief Description:  Forward Fuselage and Rear Cargo Area
Today was catch up day. First, I removed the nuts on the AN-7 landing gear bolts and added another washer. With one under the head and one under the tail of the bolt, it had bottomed out. I was able to torque it correctly. Thanks to Charlie for the extra washers. Then, I spent some time installing the AN-3 bolts in the engine mounts, both top and bottom. Finally, I made/installed the gussets on the aft side of the rear cargo bulkhead. See pictures 2 and 3.
Upper Engine Mount
Upper Engine Mount
Rear Cargo bulkhead gussets
