Jerrys Web Site
Date:  11-26-2013
Number of Hours:  5.00
Brief Description:  Final Clean Up
Today, I spent some time deburring the rivet heads on the right aileron and the left wing. At times, the mandrels leave a rough edge that needs to be filed down or hit carefully with a dremel tool. Then, I match drilled the access covers (six of them) for the right aileron. I drilled the skins out to #12 and then filed a small notch with a round jewelers file purchased at Harbour Freight. Then, I inserted the rivnuts with some proseal under each head. Picture two shows rivnuts in place and a cover made for the next hole. To pull the rivnuts, I'm using a tool purchased from ATS or one of the equivalents. It's approximately $100. I found the cheaper ones simply did not work for production quantities. I ordered the keyed rivnuts from Aircraft Spruce. To dimple the access covers, I used a homemade dimple die made by may friend Charlie Eubanks, similar to the pop rivet tool dimple dies sold by Avery tools.
When complete, I then began to layout my Vortex Generators. I'm using the Lexan type from Landshorter.com. After reading the variety of literature on line and speaking with others flying Super Rebels, I decided to put the high point of the VG at the 10% line (6" back from leading edge). That allows them to start in front of a rivet line and not interfere with a series of stringer rivets. I purchased some 3M adhesive at NAPA to install them with. I used the lateral placement recommendations from Stolspeed.com with closer spacing near the wing tip to help the tips not stall too early.
Rivnut Holes Drilled and Keyed
Nuts in place and Covers Dimpled
Laying out the Vortex Generators
