Ebby's Hatz Classic
Date:  2-23-2004
Brief Description:  Push Tube End from torque tube to idler.
A 5/16 hole was drilled about 1 inch up from the marked bolt hole. The tube was split and flattened to the end. A doubler was tack welded onto the side of the flattened tube. Both idlers were drilled to size before tack welding. This is different than
