Brief Description: Control stick inner push tube connection
This tube goes inside the torque tube to connect the forward, aft control sticks and the elevator pushtube between the torque tube and the idler. Each end is different and I always had to keep in mind that I didn't have any more 1" tube to remake control
Drilled the end 3/8" then clipped off the outer third.
