Brief Description: Drilled 5/16" flying wire to fuselage holes
Carefully drilled the three 5/16" holes in the fuselage to flying wire attachment tab on each fuselage side. Had to bend this tab to the correct angle first. Holes drilled progressively from 1/8" to just smaller than 5/16" then reamed to the correct size for the clevice pins. Deburred all holes and trial fit the clevices. All fits very well.
