Brief Description: Clear Coat ailerons and fuselage levelling
Applied a coat of Clear Coat to each aileron today. Soaked in well so will need another coat tomorrow. Started thinking about joining the upper wing to the fuselage so did a trial level to see how it will all fit. I used actual measurements from the wing to calculate where I need to cut the mounting tubes on top of the cabane struts. These were left intentionally long so that any minor adjustments could be made once the upper wing was complete. Need to work out how to cut these tubes so they are exactly square!
