Brief Description: Ailerons hung for checking of level and clearance
With the hinge base bolted to the spars, I connected the ailerons to check for level and clearance. The laser level showed that they were perfectly in line and there appears to be good clearance at the leading edges. I also just wanted to see how it looks! Upper wing getting close to being finished! Still got a few more things to do (Clear Coat the entire wing, build the aileron coves, centre attach plates, centre bow, leading edges...)
