Jon's Skybolt Project
Skybolt
Upper ailerons - gluing tips
Drilled the 3/16" holes in the aileron spars for the hinge brackets. Then glued the root and tip ribs in-situ using clamp blocks to make sure the distance from aileron spar to rear wing spar is the correct distance.
Clamping in position
Root rib and tip rib glued
Glued
Skybolt Home
276
Rigging
226
Workshop
