Brief Description: Bevelling the ribs to 6.5 degrees
Filed each rib to 6.5 degrees to allow for the 6.5 degree sweep back of the wing. A small amount of wood was filed from the inside gap of the forward spar and each spar slot was "tidied up"to allow each rib to easily slide onto the spars.
