Brief Description: Glued aileron tip and nose ribs to aileron
Spent quite a few hours laser leveling the starboard wing in the wing jig and trial fitting the starboard aileron. Took a while to align the tip rib and eventually used the laser level on each centre-line to make sure it was correct. Consulted the Biplane Forum to see what others did with the taper towards the tip. I have decided to stick with what the plans require.
Used my micro scale to carefully mix the right quantities of T88 epoxy resin with the hardener (1:0.83 by weight).
