Vans RV-8 G-JBTR
RV-8 Build Log
Antenna Doubler 3
I then bent the doubler to about 75 degrees down.
Removed the doubler and then placed the OB section under the angle and then bent this level.
Result ........ see next entry
BBend down to about 75 degrees
OB peice under angle
Bend to level
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
