Vans RV-8 G-JBTR
RV-8 Build Log
Antenna Doubler 2
I bent the flange using some 4 x 2" and completed the flange to 90 degrees with a hand seamer.
The next task is to make the joggle to fit over the F-815 flange .....
Place the doubler against F-814 and the forward edge of the doubler was 8 5/8" from the aft part of the centre section lower flange.
Mark the inboard (IB) and outboard (OB) of F-815 onto the doubler. Cut along the OB line and debur.
Mark the IB line onto the reverse of the doubler and align that under some angle on the back rivet plate (no setback this time)
Bent flange
Mark F-815 onto doubler
Invert doubler and align IB line
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
