Vans RV-8 G-JBTR
RV-8 Build Log
8-10 to 12
Centre Section
I had a local wood fabricator make up the hardwood spacers to simulate the spar and as you can see they did a great job getting the width spot on!
I recommend that you install the AN470 rivets before the Forward Control Mount/Seat Belt Lug to ensure no interference with the squeezer.
If you are installing the Rear Rudder Pedal Kit don't forget the nutplate holes to drill on the top plate (match drilled from the flange of F-804A)
Hardwood spacer - spot on!
AN470 rivets/ Fwd Control Mount
Centre Section Complete
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
