Vans RV-8 G-JBTR
RV-8 Build Log
Internal Pitot 2
Cut using pipe cutter
Add the sleeve and nut - DOUBLE CHECK ORIENTATION - then flare
Remove the bushing in the rib
Cut
Add fittings then flare
Remove bushing
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
