Vans RV-8 G-JBTR
RV-8 Build Log
Main spar Countersinking 4
Note screw is just below surface as mentioned in Section 5E of the build manual to accommodate the dimple.
I decided to CS all the #8 for both spars, then all the # 6's for both then all the #40 rivet holes to save adjusting the microstop.
Unclamp
# 8 screw
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
