Brief Description: Wrap Up Phase - My Favourite Tools
During the wrap up you will almost dispair at the number of screws to do and some are akward - until you buy a "SCREWDRIVER/ DRILL FLEXIBLE EXTENSION" tool. - just search on ebay.
The only slight problem I found is if you don't hold onto the plastic above the bit holder but you hold lower you can twist the clip that hold the locking ball bearing and PING out it comes! Hold the plastic and its brilliant.
The other item I couldn't have done without in this phase was the crawler with head support that I bought from LIDL some time back. It makes fitting the fiddly aileron fittings and doing all the underwing screw panels a much easier chore than it could have been.
So much so I will be packing this in the baggage bay when I take her to the painters to disassmeble/re-assemble.
