Vans RV-8 G-JBTR
RV-8 Build Log
Ch 12
Cowl 1A - Most Important Tool
This is the most important tool when sanding the sides/rear of the cowls.
Used a 4" x 2" x 39" plank with 80 grit roll glued onto it.
Another useful tool tip I gleaned was glue some 80 grit to a wooden tongue (mixing stick) to make a file for joints.
80 Grit Sanding Board
80 Grit file
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
