Vans RV-8 G-JBTR
RV-8 Build Log
Ch 12
Cowl 9 - Drilling Bottom Hinges
Drilled the hinges - the magic tape worked a treat.
Marked out the trim line for the top cowl sides.
Promised to show the top hinge pin cut out explained in
Cowl 1
Continued .....
Drilled Bottom Hinges
Marked top cowl for the side cut
Top Hinge Pin Cut Out
RV-8 Flying Log Home
RV-8 Build Log Home
4096
Electrics
Fibreglass
55
460
Finish
Freight
Inspiration
Panel
Primer
Registration
Research
Safety
Smoke System
Support
Test Phase
The Big Move
Tips
Upholstery
808
Workshop
Wrap Up
