Vans RV-8 G-JBTR
Date:  8-4-2010
Number of Hours:  0.00
Brief Description:  Wing drilling clamp
The wing drilling session was made significantly more stress free thanks to the loan of a clamp from Gary Smith, a UK RV builder.
It comes with three bushings :
* 1/8"
* #12
* 5/16"
As we wanted to ream the hole we used a 9/32" drill after the #12 and then reamed 5/16".
For UK builders who want to borrow this make a plea on the RV Forum to see who is the current custodian. If you are elsewhere and want to make your own my only suggestions would be:
* Make the main bushing base 5/8" radius as this will then equate to your minimum edge distance
* If you intend to ream make a 9/32" bushing.
Thanks again Gary - brilliant tool
Clamp components
Clamp components
Clamp in position
Clamp in position
Clamp view from drill side
