All went well except whilst inspecting the engine I noticed the exhaust was slightly loose and found a hanger support bolt missing. I can only conclude that originally I did not use the correct length bolt .... there are two on the sump longer ..... and that is one of them!
Jill helped do a lot of the screws which made life a lot easier. Thanks Jill xxxx
