Brief Description: Mounted Flap Position Transducer
In order to provide a front panel display of the flap position, I bought a Ray Allen position sensor to couple to the flap actuator. I found a mounting place inside the center console where the flap servo motor is located. I bent up a piece of .030" aluminum sheet to form a ramp to mount the sensor to. The sensor has a sliding actuator that must be connected to some part of the flap levers. I believe I can connect it directly to the main lever arm.
