Brief Description: Cut forward windscreen from canopy
After cutting the windscreen away from the canopy, I fitted the frame onto the fuselage to check the fit. I filed the front end of the windscreen on the bench. I then clamped the canopy onto the frame in preparation for drilling holes for rivets. I marked the frame where holes need to be drilled.
