Brief Description: Built main elevator control rod
Set up the bellcrank and built the elevator pushrods. Put in the large pushrod between the bellcrank and the elevator horns. Did minor adjustments on the clevis's, but waiting to get the rod painted before setting the final length. Clamped the vertical stabilizer to the back end to see what it looks like. At this point I had to getting and make noises. Getting closer and closer.
