Brief Description: Drilled incidence holes, set tank brackets
Remeasured all the critical parts and decided to procede to drilling the rear spar bolt holes. Proceeded just as the instructions described. Everything went really well. I then proceeded to work on the forward tank brackets. Bent then to conform to the tank mounted bracket and the fuselage. Mounted the brackets onto the side of the fuselage and then drilled the hole in the tank bracket to finish up. Finally, I bent the tubing to connect the tank and fuselage vent lines. This was fairly straightforward using the tube bending jig. I've become quite friendly with this tool. Took me a while to get onto its good graces.
