Brief Description: Clean up, move fuselage to hangar.
Cleaned up all the paint equipement and spray booth and moved the fuselage to the hangar in preparation for hanging the wings. Releved the fuselage in both directions. Was pleased to see that there was 0 degrees of twist after riveting the back top skin. I used the shimming technique with the digital level to make sure everthing was as close as I could get it. What I do is get the level to zero and then use index cards to shim up one side of the level until it reads 0.1 degrees. I then remove those index cards and do the same thing on the other side of the level until it reads 0.1 in the other direction. I then average the number of cards and shim up the side that's low with that many cards. I used this technique to determine if there was any twist.
