Sprayed the interior with Ranthane Glacier White paint. I applied very thin coats leaving about an hour in between for setting. Sprayed the bottom surfaces first working my way up the sides. This might have been the wrong direction because I did get some overspray in the bottom surface paint. The end result was not as goot as what I was able to achieve with the small parts, but I'm reasonably satisfied. I intend to work the surface with compound to take out the over spray and dust. Overall, I'm reasonably pleased. Pictures show the end result with the masking materials removed.
