I finished up the seats and started on the forward covers. I discovered that I put in the outside bottom longerons in backwards so that the angle upright is on the outside instead of the inside. I check all the prints and couldn't find a problem with this, so I decided not to remove them and switch them around. I had to cut notches into the covers, though to allow for this. Drilled all the holes for the forward covers and prpared them for nutplates.
