Finished up the rudder pedal installation by drilling the holes for the assembly into the forward auxiliary longerons. I drilled 5 sets of holes to allow for adjustment in the pedal location. I also attached the center support onto the firewall. I did not drill the holes for the block in this support because the centerlines are differant than the outside blocks. I'll drill these holes after final position is established.
