Brief Description: Installed fuel pickups and plates
Did the final assembly on the fuel pickups, sealing the rivets in the anti-rotation bracket and the fitting through the plate wall. Added plenty of sealant to the threads of the fitting and to the spacer to assure that it is leakproof. Finally, safety wired the interior fitting nuts to the anti-rotation bracket as called out in the service bulletin. This sucker is not coming apart. Finally, attached the plates to the inboard ribs. I used Tite-seal light instead of the sealant, because I've read on some of the email lists that its easier to get off if you aver do need to get inside the tank. I should have waited till after the baffle was installed to do this. Had some difficulty squeezing the rivets next to the service plate.
