Brief Description: Assemble stiffeners to right tank
Assembled the stiffeners to the right tank and the fuel fillter flange and drain flange to both tanks using sealant. Note the picture does not show the vent tub holder tab assembled to the fillet flange. This was added later. I forgot to retake the photo. Both tanks are ready for rivetting ribs to tank. The masking tape really helped to keep the skin surfaces as clean as possible. After rivetting the tank filler flange, I found it was important to cleco the ribs in place to make the proper contour on the top skin in order for the sealant to set as it should when the tank is finished. It also sets the tanks up for the next session, which is rivetting the ribs.
